It is currently Sun Sep 06, 2026 10:45 pm
 Post subject: Matchless Spitfire
PostPosted: Fri Apr 25, 2014 4:44 am
Could anyone provide me with the correct specs for the transformers and choke in a Matchless Spitfire. I am planning to make one and as i am in the UK it's not cost effective to order from USA. i have a transformer builder nearby, i just need the specs.
 Post subject: Re: Matchless Spitfire
PostPosted: Fri Apr 25, 2014 8:07 am
You can pull the specs off this schematic posted here..
viewtopic.php?f=12&t=500
PostPosted: Mon Sep 08, 2014 4:10 pm
I'm also wanting to build a close of the Matchless Spitfire, and looking for the correct transformers. Is the Trinity 15 circuit similar to the Spitfire? I saw on your current product page that the TC 15 is a two channel amp. Is this original Trinity 15 single like the Spitfire?
PostPosted: Mon Sep 08, 2014 5:14 pm
The Spitfire is a basic amp and while there is some commonality with the TC15 and Lightning, I would not recommend you use those schematics. Just search for a schematic on line and you will find it .
My thoughts on this have always been that you are 80% there with the Spitfire so why not go the distance and build the TC15?! Or at least the Lightning?
PostPosted: Tue Sep 09, 2014 9:30 am
Moved to The Dressing room.
