It is currently Thu Mar 28, 2024 3:33 pm
 Post subject: Amp Chassis Building
PostPosted: Wed Nov 27, 2013 5:47 pm
Hi, I need some advice on how to drill holes for tube sockets in an aluminum chassis. The holes need to be 1 3/16" and I don't have a step drill that big. Would a holesaw be the best tool?
Thanks, Dave.
 Post subject: Re: Amp Chassis Building
PostPosted: Thu Nov 28, 2013 12:32 am
goindeaf, ME TOO, :rol
Hole saw would be okay, best if in a drill press at proper speed.
HTH,
Gene
PostPosted: Thu Nov 28, 2013 12:10 pm
Go easy on the hole saw & it should work. If you can, use some cutting oil or lubricant to help. A punch that size can run around $50, but you could get one from Home Depot or similar place.
PostPosted: Thu Nov 28, 2013 12:43 pm
Thanks guys, I'll give the holesaw a try.
Dave.
PostPosted: Fri Dec 02, 2022 10:32 am
goindeaf wrote:
Thanks guys, I'll give the holesaw a try. foodle
Dave.
I use cutting oil to help with my sawing problem very well. Have you tried yet?
PostPosted: Thu Nov 02, 2023 7:21 am
If you're careful with the hole saw, you should be fine. Use a lubricant or cutting oil to make things easier. You may find a suitable punch for the job for roughly $50 at Home Depot or a similar store. wordle today
