It is currently Sun Sep 06, 2026 10:45 pm
 Post subject: cheap oscilloscope
PostPosted: Sat Jan 10, 2015 1:00 pm
hi all, I was just troubleshooting my amp and i just thought man if I just had an oscope figuring out where this nasty distortion is coming in would be so much easier. started to look around and saw some low cost pocket oscopes but have no idea if they are even worth the money. Since I only want/need it to solve a short-term problem I dont want to spend anymore than I have to on it. I dont need any advanced features, would just like to view the waveform and look for anomolies. Anybody have recommendations?
thanks,
Don
 Post subject: Re: cheap oscilloscope
PostPosted: Sun Jan 11, 2015 1:04 pm
This is the one that people are raving about. When I eventually get one, this will be it.
http://www.amazon.com/Rigol-DS1102E-Oscilloscope-Channels-Sampling/dp/B001VKCJ0M/ref=sr_1_1?s=industrial&ie=UTF8&qid=1420995781&sr=1-1&keywords=oscilloscope
At that price, it's totally worth just skipping a limited pocket o'scope and getting a very useful tool that will serve you well for a long time.
PostPosted: Sun Jan 11, 2015 2:23 pm
Really like this one too. Keep meaning to pick one up.
Would a audio probe work for your trouble shooting? Cheap and you can build it yourself. A very useful tool for tracking down and isolating problems.
PostPosted: Mon Jan 12, 2015 1:17 pm
audio probe probably wouldn't hurt. I will look out for plans to build one thanks!
PostPosted: Mon Jan 12, 2015 1:21 pm
yea I was looking at the pocket scopes and the PC based scopes; most reviews are not favorable for any of them. If they would work well enough for my purposes I might try and pick one up. 400 bucks is out of my price range. I will try and verify voltages again using DVM but it seems like they are all fine last time I checked.
thanks!
PostPosted: Mon Jan 12, 2015 4:58 pm
If you only need a scope for this project maybe you can borrow one or use a schools/community colleges?
PostPosted: Mon Jan 12, 2015 8:37 pm
that is a good idea I can definitely look into that. Actually I think my company might have some engineering departments that might have some of these but I would have to track someone down that would let me in that area. still worth a try thanks
PostPosted: Tue Jan 13, 2015 12:52 am
thanks!
I was in the same boat as you. I was looking into getting a PC-based scope and even building my own using a sound card. After not finding one that could meet all my needs (I do electronics other than tube amps too) I decided it would be a waste of money to buy a cheap scope only to find out it would not meet my needs down the road. So I decided to save-up until I can afford the $400 Rigol and just make-do without for now.
You could also check Craigslist for a used bargain in your area. I've seen halfway decent analog scopes on there in my area for under $200.
PostPosted: Tue Jan 13, 2015 9:07 pm
i got my Tektronox off kijiji for a good price.
PostPosted: Sat Feb 14, 2015 4:52 am
I have a tenma 50MHz... nice for the price but I almost never use it :/
Corey
PostPosted: Sat Feb 14, 2015 9:49 pm
wow nice!
Corey
PostPosted: Sun Feb 15, 2015 12:08 pm
I think less than $300 but that was quite a while ago!
PostPosted: Sun Feb 15, 2015 6:18 pm
yoiks! that's a steal, well done :shock: :)
Corey
PostPosted: Mon Feb 16, 2015 2:22 pm
I just kept patiently looking once I knew what I wanted. I had another which I then gave to kurtlives!
