It is currently Fri Apr 17, 2026 4:34 pm
 Post subject: tube fx-loop
PostPosted: Tue Feb 17, 2015 7:29 pm
Hey I just saw a post on one of the facebook groups about a tube based fx loop on a circuit board. Has anyone tried this? I was thinking about getting one and trying it out.
 Post subject: Re: tube fx-loop
PostPosted: Sun Apr 26, 2015 12:42 am
Damm never look in this part of the forum
This one has always interested me .
http://www.tube-town.net/ttstore/Kits/Misc-Kits/Kit-Tube-FX-Loop-6112::5992.html
But there also links to many different type of tube and non tube loops out there. Hoffman forums has a few some just point to point right over the tube socket. Will also depend on what amp you want to integrate it too
PostPosted: Sun Apr 26, 2015 8:22 am
A FET based one is probably just as good but with less appeal. I think that one on that forum would be very good tho. We were going to try one and started to discuss becoming the Canadian rep, but just no time so far. If you give it a go, please let us know what you think.
PostPosted: Mon Apr 27, 2015 4:38 pm
I agree. Unless your effects are all tube, your signal is going to hit FETs, OpAmps, maybe even go digital for a time anyways.
Do you have a favorite FET schematic?
PostPosted: Mon Apr 27, 2015 6:46 pm
For the buffer portion of the FX loop a FET is as good as a tube tone wise. I have used HV MOSFETs as source followers (buffers) a few times with great results.
http://www.geofex.com/Article_Folders/m ... tfolly.htm
It's the recovery stage (gain stage) that you want to be tube. Often times overdriving (clipping) the recovery stage is part of the amp's tone.
PostPosted: Tue Apr 28, 2015 8:20 pm
Yes that is often the goal from the get-go, but if your design goal is to have as "transparent" a loop as possible, then there is no need for tubes at all.
