PostPosted: Wed Jan 18, 2006 9:43 am
I don't normally do this, but I was fussing around a specific TMB build and thought I'd try it and see if I could eliminate all hum. It didn't make much of a difference, but I had a heck of a time soldering the 22 guage buss bar to the back of the Alpha pots. I'm not happy with the soldering quality so ..
Any tips for doing a good job on soldering the buss bar?
P.S. there is no hum at all on the build.
PostPosted: Wed Jan 18, 2006 8:24 pm
I've found that a thick gauge bus bar tends to almost act like a heat sink...and it disipates heat quicker than you can apply it, when using a regular 30w soldering iron.
I've resorted to using my weller 100w/140w gun on bus bars with good success. I set it to 100w and go to town. It allows me to get a good solder connection quicker and since the bar itself seems to disipate the heat, it doesn't damage any connected components.
PostPosted: Wed Jan 18, 2006 8:38 pm
Well, I lifted the buss bar off the pots and there was no change in hum. In other words, the TMB was still silent. So, as a result, I won't use this grounding technique.
PostPosted: Wed Jan 18, 2006 9:32 pm
I wrecked a CTS pot trying to solder a ground on it so I never do it now.
Nigel
PostPosted: Wed Jan 18, 2006 9:46 pm
Ooohh. Now that hurts. I think the idea is founded in 'history' and that's where's it going to stay As Far As I'm Concerned.
PostPosted: Thu Feb 09, 2006 10:38 pm
Use flux. This will help draw the solder to the metal. Pick some up and try it on a couple of solder joints. You may not use this type of buss in a new build but you might find yourself repairing someones amp in the future (replacing a pot for example).
PostPosted: Fri Feb 10, 2006 12:11 pm
I usually rough upthe back of the pot with a dremel, when do solder a buss wire across the pots.
PostPosted: Tue Mar 14, 2006 8:19 pm
I turn on the bench grinder for a few seconds, that does the trick
PostPosted: Tue Mar 14, 2006 11:54 pm
Thanks, I decided not to solder the pots in the end. And I have no hum either. I'll stick with the ground buss approach.
