It is currently Fri Apr 17, 2026 6:00 pm
 Post subject: Chokes: Pros / Cons?
PostPosted: Thu Mar 16, 2006 9:39 pm
My understanding of chokes is they smooth the ripple of current / power. So why do some amps have them and other don't?
PostPosted: Thu Mar 16, 2006 9:59 pm
Caps store voltage whereas chokes store current. You are correct in your statement that chokes smooth ripple in the power supply, but their real benefit is to provide extra current to the screens of the power tubes.
Generally speaking, an amp that uses a resistor in place of a choke will have a grittier sound and a looser bottom. A choke will make the amp sound a little more refined.
There aren't really pros or cons to chokes--it is just a matter of taste. I happen to like them.
You just need to make sure your screens are protected if you use a choke in place of a resistor since chokes don't drop as much voltage as an OT does.
--s2
www.s2amps.com
www.category5amps.com
PostPosted: Thu Mar 16, 2006 11:02 pm
To add to s2, I know when I built a certain 15 watt amp, it wasn't until I put the choke in, did all the hum finally go away.
PostPosted: Thu Mar 16, 2006 11:11 pm
And the funny thing, is that I took the choke away from the same type of amp and noticed no difference....so your milage may vary...
PostPosted: Thu Mar 16, 2006 11:22 pm
Did you notice any change in tone - to s2's point - Resistor = grittier sound, looser bottom. Choke = sound a little more refined.
PostPosted: Fri Mar 17, 2006 1:07 am
Yes, definitely slightly grittier....but as far as noise is concerned, no difference in noise...and I actually lost one of the 22uf caps as well... :)
 Post subject: Re: Chokes: Pros / Cons?
PostPosted: Fri Jul 16, 2010 12:59 am
I am excited about testing out a choke on my tc-15. :chatter:
