It is currently Fri Mar 29, 2024 10:49 am
 Post subject: Reissued Mullard 12AX7
PostPosted: Fri Sep 20, 2019 6:01 pm
Has anyone tried the re-issued Mullard 12AX7. If so, what are your impressions of it and the other Mullard re-issues?
PostPosted: Sat May 09, 2020 2:15 am
I've used them in a Dual Terror and the Egnator amp from the seminar (20 watts). They sound much better to my ears than the JJ's both those amps came with. Great cleans...good break up and sound pretty clear with the medium/light crunch I typically use. I know they aren't the NOS ones... but I would consider them a step up from the JJ's.
PostPosted: Sat Feb 20, 2021 5:44 am
My hubby using the Egnator amp, and they sound too good and better than before, he bought it from Reecoupons last month, if you wanna buy check on there, you will find more options.
PostPosted: Tue Mar 22, 2022 9:42 am
The transconductance on my sample was the same as two NOS samples I measured. Not really high gain at all, but a real good noise floor and a nice smooth tone that doesn't encourage ear fatigue the way some preamps can be." The Mullard name and trademark have been acquired by the New Sensor Corporation.
Visit: Olight discount code
PostPosted: Wed Dec 21, 2022 9:09 am
List of the Best 12AX7 Tubes
Genalex Gold Lion ECC83/B759 (Best Overall) Check Amazon Price. ...
JJ 12AX7/ECC83 (Best Value) Check Amazon Price. ...
Electro-Harmonix 12AX7EH (Best Under $50) Check Amazon Price. ...
JJ ECC803/12AX7 (Best Under $30) ...
Mullard 12AX7/ECC83. ...
Tung-Sol 12AX7. ...
Sovtek 12AX7LPS. ...
Mullard 12AX7/CV4004.
Bookngly
