It is currently Sat Apr 18, 2026 3:22 am
 Post subject: It's hard.
PostPosted: Sat Aug 26, 2006 6:56 pm
It's hard having nothing to solder...
PostPosted: Sun Aug 27, 2006 12:42 am
So have you cleaned up the Lightning and got all the problems sorted out now? Maybe it is time to start a sIII 18Watt TMB, I have just started my second one, built the board yestareday and I am just starting on the chassis.
Nigel
PostPosted: Sun Aug 27, 2006 3:00 am
Yep - it's doing great. I've built drum kits (http://www.languagepool.net/webs/chalkb ... image0.jpg), don't know how many guitars, but this is the first thing that's really made me proud to play. I wish I could convince myself that building another amp would be something I could find a need for. I was thinking about the DC-30. But I like this amp so much, I can't convince myself that I wouldn't hinder myself by making another. I don't think I'd use either of them in as fully of a way as I'd use and spend time with one of them. I think I'm going to pick up The Tube Amp Book to try to learn more about what's happening in the Lightning to produce the sound it does.
PostPosted: Sun Aug 27, 2006 9:01 am
The Marshall sound is just not something you're going to get out of a Lightning. So if you had one of each ... then you'd always have an option.
I guess, there's always pedals if you must solder! or you can expand on the lightning (EF86).
PostPosted: Mon Aug 28, 2006 9:35 pm
I've already thought of some mods I'd like to do. Nothing major. I want to make the cut permanent. I have it up all the way, so I might as well just put the cap on the master and eliminate some wire. And I want to add a standby.
