It is currently Mon Apr 20, 2026 6:02 am
 Post subject: Mains Wiring in Europe
PostPosted: Fri Jan 26, 2007 3:59 pm
I am building an sIII for a customer in the Canary Islands. 220V/50 Mains. Looking into plug types, it appears there may not be a ground pin? Just two round pins?
Can anyone confirm how the mains wiring is done and which is the correct plug type (2 or 3 pin), Euro part number etc. in Spain/Canary Islands?
Thanks for your help.
PostPosted: Tue Apr 03, 2007 6:37 pm
A normal european grounded plug should do fine
The outlet you are most likely to find in the Canary Islands is the European CEE7/7 "Schuko" wall outlet.
IEC884-1 (with ground)
http://www.buytravelconverter.com/canary_islands.aspx
Mains wiring for europe (220V) as in my schematic:
http://home.online.no/~eber-ha/TubeAMP/ ... emV1.2.htm
Espen
PostPosted: Tue Apr 03, 2007 7:12 pm
That's the one. Thanks. I found out what kind it was from him and shipped it out. Apprently, it worked perfectly!
