It is currently Mon Apr 20, 2026 5:59 am
PostPosted: Thu Jun 28, 2007 7:14 am
Has anyone tried to reduce the power output by using the 12AU7 as Output tube? How did you do it? How did it sound?
Did you try other tubes as well?
PostPosted: Thu Jun 28, 2007 9:34 am
For my next project I might try useing a 6sn7 tube for a push/pull power amp and a mate it to a HG 100 preamp. See links below for schematic of power amp and discussion on the HG 100 preamp. Just looking for a good high gain marshall sound that will sound good at low volumes.
2w push/pull scheamtic
http://www.ax84.com/static/corepoweramp ... ematic.pdf
HG 100 preamp discussion
http://forum.metroamp.com/viewtopic.php ... ea52353221
You might have to join above sites to get info!!
HG 100 Schematic(just get schematic in this thread only)
http://www.18watt.com/modules.php?name= ... ight=hg100
PostPosted: Thu Jun 28, 2007 2:22 pm
Actually, I was thinking of just putting them into an 18 watt design; not a new amp!
PostPosted: Thu Jun 28, 2007 4:01 pm
I'm going to guess this is a dumb question. Why not just put a 12AU7 in one of your 18 watt's :?
PostPosted: Thu Jun 28, 2007 6:49 pm
You did not say 18watt design :P
Try this schematic
http://members.cox.net/dennisfweb/images/18w_AU_3.jpg
site
PostPosted: Thu Jun 28, 2007 6:53 pm
Or just put something similat to his power supply from AX84 on the front of an 18watt circuit.
PostPosted: Thu Jun 28, 2007 9:20 pm
Anything lower power that will work with an 8K or 5K OT?
PostPosted: Fri Jun 29, 2007 5:10 am
Following on from my post in the Practise Amp thread, just wanted to say that in my experince of 2 builds, using a 12AU7 as the output stage of an 18W lite works really well. It's a great sounding amp. :wink:
Powered by propellor shoes, flying sub ahoy!
PostPosted: Fri Jun 29, 2007 9:28 am
I think if you wanted to build a push/pull amp with anything less than EL84 you will need different PT and OT than the ones you sell.
I think alot of the people who build their own amps find out that even a el84 amp is way to loud for home use. Master volumes and atteunators will work but they suck alot of tone out of the amp when they are used.
That is why I am going to give the 6SN7 tube a chance in a push/pull power amp mated to a hot rodded marshall preamp. I am strictly a at home player who wants to have good tone at low volume levels.I think you would even be suprised by the volume this type of amp produces.
I think there would be a high demand for this type of amp.Market is not saturated like the 18watt's are.
PostPosted: Mon Jul 02, 2007 1:12 pm
i'd like to see this topic develop. i have some 12AU7s laying around....
would it be impossible to do power tube switching like in the V6, but using the el84s and 12AU7s?
PostPosted: Mon Jul 02, 2007 1:32 pm
Pretty much lost cause as they require a much different output transformer impedance. I think you could use the 6AQ5 instead of 6BQ5 / EL84 for a minor drop in power.
Edit - No you cant - wrong pin-out. :oops:
However, if you used a really small OT like some designs I've seen, you could switch both tubes and OT. :D
PostPosted: Mon Jul 02, 2007 9:15 pm
Isn't the 6AQ5 a seven pin tube? You can't just plug-n-play can you?
Check this site's tube section: "http://www.nostalgiaair.org/".
PostPosted: Mon Jul 02, 2007 11:01 pm
Darn right you are. Where did that idea come from?
PostPosted: Tue Jul 03, 2007 10:32 pm
who knows, but boy do I have a lot of 7-pin sockets :lol:
