It is currently Wed Mar 11, 2026 2:43 am
PostPosted: Sat Jan 30, 2016 12:40 am
Here is a picture of the Heyboer Transformers that will be shipped with the newest addition to our line-up, the TriFly. The TriFly is not a toy or a novelty amp! Having 2, full-size 9 pin tubes means interchangeability with both new stock and NOS tubes if you are searching for a special tone. Use the supplied 12AX7 or swap in one of several lower gain preamp tubes or switch from the supplied 12BH7 to 12AU7 for even lower power. A classic design power supply is used, not a cheap switching or charge-pump design. Eyelet board based, point-to-point wiring means you can tweak the tone to your heart's content using classic design techniques and the powder-coated Red Sparkle enclosure is a dual pedal size that can fit in your kit bag! Kits are $290US. Shown in the picture is a raw enclosure. Taking orders now. Message me for more information!
PostPosted: Sat Jan 30, 2016 7:27 pm
Those are some hefty transformers! :thumbsup:
PostPosted: Mon Feb 01, 2016 9:10 am
The OT is about 3X the aize of the Hammond alot of people use in small amps like this. But the Hammonds sounds appalling !!
