It is currently Sun Apr 05, 2026 8:53 am
 Post subject: 16 Ohm tap on OT
PostPosted: Mon Feb 13, 2017 10:57 pm
Hi all, just finished my Tri-fly pcb build, and was wondering if there are any issues with using the 16 ohm tap off of the OT. I have several low wattage speaker cabs that I typically like to use with low wattage amps, and of course they are all have 16 ohm speakers. I would just substitute the 16 ohm tap for the 4 ohm tap, which I don't plan on using. From what I understand about amps I'm assuming I could just use the 8 ohm tap with a 16 ohm load, which would draw less current from the OT anyways, but why not use the correct tap, as it is readily available? Any advice or recommendations would be great!
-Chris
 Post subject: Re: 16 Ohm tap on OT
PostPosted: Fri Feb 17, 2017 6:07 pm
Hi Dart,
I can't find a schematic or a wiring diagram of the trifly, but according to the picture in http://www.trinityamps.com/phpbb/download/file.php?id=1824&mode=view, just wire the 16 ohms tap (the orange wire?) instead of the 4 ohms and you will be fine. As you said, you can also use a 16 ohms speaker in the 8 ohms output (but never the reverse: a 4 ohms speaker in the 8 ohms output), but if the 16 ohms tap exist...
PostPosted: Mon Aug 22, 2022 4:27 am
A really great idea. Thanks for suggesting me.
we become what we behold
