It is currently Wed Jun 24, 2026 11:46 pm
PostPosted: Wed Jan 20, 2021 12:33 am
The instructions mention using a wire brush to clean up the paint from various holes such as the speaker Jack holes, etc. The inside of the chassis is clean without overspray. Is it only referring to the inside of the hole, or do I need to clean up a margin on the face of the Chassis for any reason?
**** EDIT ****
I ended up emailing Trinity and was told that there's no reason to clean up a margin on the face. You only need clean up the inside of the chassis if there is overspray. I ended up using a wire brush on the dremel around the holes on the interior just in case there was any coating or varnish type material on the inside, which is what it appears they show on the pics on the kit page.
