It is currently Fri Jun 26, 2026 12:27 am
 Post subject: A few questions
PostPosted: Thu Apr 29, 2021 2:52 pm
I maybe overthinking this, im just making sure I'm using the correct resistors and led for this? The diagrams called for metal film 100k resistors in the preamp section. Pretty sure these are carbon film. there were 6 of the tan and 2 blue that came with the kit.
About the led, I think I was either short one, or more likely knocked off my bench and swept up. I used a 5mm red led in its place I have stocked for pedals. I've tested it, and it blinks while the other stays lit. I've attached a picture of the relay board and eyelet board.
These may be stupid questions, but im trying to make absolutely sure im on the right track. Any answers or comments are greatly appreciated!
 Post subject: Re: A few questions
PostPosted: Thu May 13, 2021 2:45 pm
Hi There,
Ill preface by saying, this is my first ever build, but I just finished and im pretty close to having it run perfect. I have some different values on my board than you do. Ill post a pic if thats helpful.
Hopefully Im not causingmore confusion.
PostPosted: Sat May 22, 2021 6:05 pm
Thanks for that! After I made that post, I read a little more about resistors and switched in the right ones. Im actually in the testing stage and trying to figure voltage issues now. But, im definitely going to compare mine to yours just to help doble check everything.
PostPosted: Sat May 22, 2021 6:06 pm
