It is currently Fri Jun 27, 2025 4:47 pm
 Post subject: AC Voltage requirements
PostPosted: Thu Jun 05, 2025 7:20 am
I have a very general question that applies to my OSD, TV15, and tramp. I have just moved and am in the process of rewiring my amps from 120v to 220v. However the power supply here to the amp is not the best and does very between 220v and 230v, generally. So the question is, is it best to wire them for 220v of 230v. Also how important is this and does it really matter.
Thank you
PostPosted: Fri Jun 20, 2025 2:52 am
Both voltages are within a similar range, and many devices are designed to operate within a tolerance of about ±10%. This means that a device rated for 220V should generally handle voltages up to 242V (220V + 10%). Operating devices at their rated voltage can help extend their lifespan. Consistently exceeding the voltage rating can lead to overheating and premature failure. age of war
