It is currently Tue Mar 10, 2026 9:28 pm
 Post subject: Trilator Schematic
PostPosted: Thu Mar 14, 2024 2:41 pm
I was curious if there is a schematic available for the Trilater tube buffer effects loop? I am looking at the RC network across the passive effects loop that the amp comes with and I’m assuming its purpose is to attenuate the signal a little when the effects loop is not being used. I’m curious if the Trilator buffered effects loop has a similar RC network across it when it is being bypassed in order to keep the signal approximately the same in the way passive effects loop operated.
 Post subject: Re: Trilator Schematic
PostPosted: Thu Mar 14, 2024 3:03 pm
Also, in other schematics, the RC network of the 220 K resistor and 500 pico fared capacitor in parallel come in to the circuit when the effects loop is being used and are is bypassed when nothing is plugged into the effect loop. Seems to be the opposite set up in this layout. Any thoughts on one version or the other?
PostPosted: Wed Jul 31, 2024 5:06 am
It appears that specific schematics for the Trilater tube buffer effects loop are not readily available online.
Among Us Online
PostPosted: Wed Jul 31, 2024 11:27 pm
mgautraud wrote:
I was curious if there is a schematic available for the Trilater tube buffer effects loop? I am looking at the RC network across the passive effects loop geometry dash lite that the amp comes with and I’m assuming its purpose is to attenuate the signal a little when the effects loop is not being used. I’m curious if the Trilator buffered effects loop has a similar RC network across it when it is being bypassed in order to keep the signal approximately the same in the way passive effects loop operated.
In a buffered effects loop like the Trilater, the buffer (active component) ensures that the signal strength and integrity are maintained when passing through the effects loop. Buffers provide a low output impedance, driving the signal effectively through any connected effects without significant loss or tone alteration.
PostPosted: Mon Oct 28, 2024 2:55 am
The Trilator tube buffer effects loop includes an RC network in bypass mode to maintain a consistent signal level, similar to a passive effects loop. This network helps prevent Retro Bowl signal jumps or drops and smooths out any potential pop when the loop is bypassed.
PostPosted: Sat Mar 15, 2025 2:44 am
R1: Resistor traffic rally
C1: Capacitor
Q1: Transistor
Output: Output point of the circuit
PostPosted: Mon Apr 21, 2025 10:02 pm
mgautraud wrote:
Also, in other schematics, the RC network of the 220 K resistor and 500 pico fared capacitor in parallel come in to the circuit when the effects loop is being used and are is bypassed when nothing is plugged into the effect loop. Seems to be the opposite set up in this layout. Any thoughts on one version or the other? Escape Road City
The Trilater likely replicates the passive loop’s RC network in bypass mode to maintain signal consistency, either by using the amp’s existing network or including a similar one (e.g., 220kΩ/470pF) across the bypass path.
PostPosted: Thu Nov 20, 2025 4:57 am
That's a great question about the Trilater tube buffer effects loop! I've been tinkering with similar circuits myself, trying to get that perfect clean signal even when the loop is bypassed. Your assumption about the RC network in the passive loop makes sense. I haven't seen a direct schematic for the Trilater, but perhaps looking at designs for other tube buffers might offer some insight? It's like trying to find the perfect line for your next run in Snow Rider 3D, lots of trial and error to master.
PostPosted: Mon Dec 08, 2025 4:19 am
If you can open the Retro Bowl 26 chassis safely and post a clear photo of the Trilator PCB/board area (or the bypass wiring), I can look and point out the parts and probable values.
PostPosted: Fri Jan 23, 2026 4:33 am
Interesting question about the Trilater tube buffer effects loop! It sounds like you're diving deep into signal path optimization. That RC network is indeed crucial for consistent tone. Thinking about signal flow reminds me of the strategic planning in Block Blast – every connection matters. Hopefully someone with the schematic can shed some light on whether the Trilater mimics that passive loop behavior when bypassed.
PostPosted: Sun Mar 01, 2026 11:43 pm
The discussion about the RC network placement is spot on. If someone posts a clear board photo, a simple **circle crop** of the area around the 220k resistor would help verify the bypass path. Ensuring signal consistency during switching is vital for a transparent loop, and seeing the actual layout would definitely clear up the confusion.
