It is currently Thu Feb 12, 2026 2:34 pm
PostPosted: Thu Apr 12, 2018 11:00 am
So,i went through everything.
Poked and measured. Even found a loose solder.
But it remains the same.
Everything works, Except, in Rock mode, the bass sound like its on full, and turning the knob doesn't change anything.
Mid and Treble works fine.
Also, Rock has more volume. Could be partly due to the bass being louder.
Engaging the mid boost, cuts out the tone stack as expected.
PAB and OD works fine as well.
The leds light on the relay board.
Measuring and probing the relay board, indicates it works as it should.
Cant figure out whats wrong.
Any help is much appreciated.
www.paradisepi.com
PostPosted: Thu Apr 12, 2018 11:40 am
In rock mode it does seem a little louder. I suspect you are correct.
Can you take a picture from above that shows the connections to the relay board?
PostPosted: Sat Apr 14, 2018 5:16 am
Found the culprit.
A loose solder on the switch fixed it.
As I suspected the sound that came was with Bass on full
Now I can get to know it.
And build a cab for it.
Everything works now.
Thanks for the help.
Hopefully I will have time to do some samples soon.
www.paradisepi.com
PostPosted: Sat Apr 14, 2018 2:52 pm
EXCELLENT!
Darn those loose solder joints!!
Head cab or combo?? Do you have our plans or need them??
Sample Clips PLEASE! We will feature them on the web site !
:thumbsup:
PostPosted: Sun Apr 15, 2018 3:58 am
I will build a cab.
Can you share the plans.
Are they metric. Not good at dealing with inches....haha.
For sure, sound clips soon.
I will do some with some different guitars.
But I mainly play Tele.
www.paradisepi.com
