It is currently Fri Jun 26, 2026 2:54 am
 Post subject: Fx loop wiring
PostPosted: Thu Mar 28, 2019 6:38 pm
The schematic shows the 3 pole switching jack as the return
and the layout diagram shows the send jack to be the 3 pole switching jack
I could use some clarification..........
 Post subject: Re: Fx loop wiring
PostPosted: Thu Apr 04, 2019 10:06 pm
Follow this layout. Schematic needs to change.
In normal operation the 220K/500pf are in cIrcuit. Plug in an effect and that os remonev fro the circuIt.
http://www.trinityamps.com/docs/OSDLayout18.pdf
