It is currently Wed Jun 24, 2026 8:17 pm
 Post subject: Relay Board Wiring
PostPosted: Fri May 31, 2019 10:33 am
If you are having problems with the relay board, wire it up using this drawing.
http://www.trinityamps.com/docs/OSDRelayBlack.pdf
The original green layout has the wrong connection from the 220K resistor (R51) on the eyelet board to the OD term on the relay board.
This was corrected for the green board here:
http://www.trinityamps.com/wp-content/u ... ut-v13.pdf
