It is currently Sun May 19, 2024 3:56 pm
PostPosted: Thu Mar 25, 2021 3:24 pm
Hi, my name is Kevin and I am wondering what speakers folks are using with their OSD amp?
PostPosted: Thu Mar 25, 2021 5:49 pm
I've tried it with a few different cabs
1. 2 x 12 Celestion V30's
2. 1 x 12 Oversize ported cab with a EVM12L
3. 1 x 12 EV SRO
4. 2 x 10 celestion vintage 10's
All cabs sounded great with 1 and 2 being the best in my opinion.
Hope that helps, Mike
PostPosted: Thu Mar 25, 2021 11:37 pm
I use the Trinity OSD cab with a Fane A60 speaker and it sounds glorious.
PostPosted: Fri Mar 26, 2021 12:48 pm
Mr. Dumble usually paired them with either the EVM12 or the Celestion G12-65. Those are usually the most popular choices. The EVM12 is a very neutral speaker and really needs the special EV ported cabinet to work well IMO... which makes for a VERY heavy package.
I use my OSD with either a WGS ET65 (their take on the original G12-65) or the Scumback M75-LD - which the Scumback guy recommended to me for a D-Style. Both are excellent speakers that sound very similar. The Scumback seems to have a little more low-end "punch" to it which I love with the OSD (probably because of the large dust-cap), but the ET65 is a little more versatile and pairs extremely well with ALL of my amps and I have this speaker in two cabinets. Both are rated at 65 watts.
I believe Two Rock uses T.R. labeled WGS ET65's in their D-Style amps/cabs.
I think between those four choices you would be very happy. If you want "accurate" go with the EVM12... if you want "smooth" go with one of the other three.
PostPosted: Fri Mar 26, 2021 4:44 pm
That's good insight, and before plumping for the Fane I was going to go with the WGS ET65. During testing I hooked it up to a cab with a Celestion Blue in it - it was gorgeous, my absolute favorite. Unfortunately, the blue is rated for 15W and just won't cut it for the OSD's 33W with 6L6s.
PostPosted: Mon Mar 29, 2021 2:47 pm
Thank you for the suggestions. Since I already have cabinets with vintage 30’s I thin I’ll start there.
I’m looking forward to building the OSD as soon as it arrives!
Kev
PostPosted: Fri Feb 11, 2022 11:03 pm
I realize this is an old thread, but still relevant IMO.
I'm running my OSD with a WGS12L (Warehouse) in a Trinity Sidewinder 1X12 cabinet. Yes it's heavy, but it sounds wonderful. I've also run it thru a closed-back Avatar 4x12 with Greenbacks. The 1x12 WGS12L sounds much better to me.
PostPosted: Sat Feb 12, 2022 9:20 pm
Jensen Blackbird 100 in an oversized 1x12 with oval rear port.
The speaker is just over 7 lbs (about half the weight of WGS12L or EVM12L). The 100 watts rating is plenty for the OSD.
PostPosted: Fri Aug 12, 2022 5:22 am
Just saw this. Thanks for posting this.geometry dash
PostPosted: Mon Dec 12, 2022 11:56 am
I only now noticed this. I am grateful that you shared this.
word finder
PostPosted: Tue Dec 13, 2022 7:14 am
Location: 390 North Orange Avenue, Suite 2300, Orlando,FL 32801
Hi All :lol:
My Name is Andrew, I am new here
PostPosted: Thu Dec 15, 2022 1:30 pm
Mr. Dumble usually paired them with either the EVM12 or the Celestino G12-65. Those are usually the most popular choices. The EVM12 is a very neutral speaker for and really needs the special EV ported cabinet to work well IMO... which makes for a VERY heavy package.
I use my OSD with either a WGS ET65 (their take on the original G12-65) or the Sunback M75-LD - which the Sunback guy recommended to me for a D-Style. Both are excellent speakers that sound very similar. The Sunback seems to have a little more low-end "punch" to it which I love with the OSD (probably because of the large dust-cap), but the ET65 is a little more versatile and pairs extremely well with ALL of my amps and I have this speaker in two cabinets. Both are rated at 65 watts.
