It is currently Tue Apr 23, 2024 10:27 pm
PostPosted: Wed Jun 02, 2021 9:54 am
Hi,
I’m just starting my OSD build and the 15pf capacitor on the master volume actually measures 45pf. Will this cause any issues or affect tone?
Kevin
PostPosted: Thu Sep 08, 2022 12:34 am
in my opinion, it won't have bad effect but if you want an answer from an expert, just wait more the backrooms
PostPosted: Thu Feb 23, 2023 3:38 am
I'm just getting started with my OSD setup, and the master volume 15pf capacitor turns out to be 45pf. Is there going to be any kind of problem with this? driving directions
PostPosted: Thu Feb 23, 2023 5:27 pm
tidinggirl wrote:
I'm just getting started with my OSD setup, and the master volume 15pf capacitor turns out to be 45pf. Is there going to be any kind of problem with this? angel numerology
Are you the original poster, or why are you asking the same question?? :?:
PostPosted: Tue Jul 25, 2023 5:14 am
I think there is no problem.
dinosaur game
PostPosted: Thu Feb 15, 2024 3:05 am
Capacitors, like all electronic components, have manufacturing tolerances. This means that the actual value of a capacitor can vary slightly from its specified value. While a 15pF capacitor may be labeled as such, its actual capacitance could fall within a tolerance range that includes 45pF.
connections
