I finished my OSD build a few dqys ago. I had a couple of minor teething problems - the biggest issue was the NFB loop. I guess I've always been lucky with the amps I've built previously - I've never had to switch the plate leads on the power tubes before. I had a hard time understanding the issue because I believed that having positive bias would be obvious with noise and squealing - it wasn't, it only happened when a certain note was played through a specific amp/cabinet combination. I'm posting this hoping that I may help another builder down the road.
It pains me to say it, but I'm sorely disappointed in the support on this forum. My first build was back in 2011 and it was a Trinity 18 Watt sIII. I had a tremendous amount of help online here. I built a Triwatt in 2012 and found much support again. Then I branched out and built a few other amps and had a ton of suuport on the Amp Garage putting together a Trainwreck inspired amp from a chassis I bought and a pile of parts. Not so much help or interest here. I hope home-built amps are not in decline, but forum activity makes me wonder.
BTW - the OSD is awesome! I might modify the Presence to make it less subtle, but otherwise the cleans are great and the overdrive is creamy smooth. It's also very quiet with no hiss unless I have the volume and master master volume up around three o'oclock or higher.
