It is currently Fri Mar 13, 2026 9:57 am
PostPosted: Wed Nov 20, 2024 9:38 pm
I've been enjoying my OSD kit for a few years and I just wondered what if?? I think the PT is ok for the extra filament load.
Would EL34s work with a slight wiring change??
PostPosted: Thu Nov 28, 2024 4:48 am
Bradman wrote:
I've been enjoying my OSD kit for a few years and I just wondered what if?? I think the Drift Boss Game is ok for the extra filament load.
The EL34 can be used with a few minor changes in the amplifier wiring as it is compatible with most amplifiers using octal bases.
PostPosted: Fri Feb 21, 2025 9:50 pm
Would EL34s work with a slight wiring change?? block breaker
EL34s can add a unique warmth to your sound! Just ensure that your amp can handle the slight wiring changes needed. It could be a great upgrade for your OSD kit!
PostPosted: Sat Mar 01, 2025 4:24 am
I've had a great time using my OSD kit over the years, and it got me thinking—what if? I feel the block breaker game handles the additional filament load just fine. Do you think EL34s could be compatible with a minor wiring adjustment?
PostPosted: Thu Mar 13, 2025 5:13 am
You will need to look at the power transformer specifications and compare this to the filament Slither io current requirement of the EL34.
PostPosted: Mon Mar 31, 2025 11:45 pm
Yes, EL34 tubes could work in your Trinity Amps OSD kit with a slight wiring change to the tube Chill Guy Clicker sockets, but you’d need to confirm your power transformer can handle the increased filament current of 3A for a pair of EL34s compared to 1.8A for 6L6s or 0.9A for 6V6s.
PostPosted: Fri Sep 12, 2025 2:33 am
That's a cool thought about pushing your OSD kit further! I'm also curious about the power transformer's limits with heavier filament loads. Swapping to EL34s is intriguing - I've heard some people get really interesting results with similar mods, though I'm no expert on the wiring changes involved. Maybe someone who's used Sprunki mods, or has experience with EL34 conversions, could chime in with their thoughts? It's always fun to explore the "what ifs" of audio gear!
