It is currently Mon Dec 08, 2025 7:38 pm
 Post subject: Coax Routing
PostPosted: Fri Jan 03, 2025 6:19 pm
Maybe a silly question, but I thought I'd ask anyways.
I'm wiring up the pots in my Trip Top build and the instructions advise to route all coax cables above the turret board. This is how I am doing it, but in photos I've seen of other Trip Tops the coax cables all seem to be routed underneath the board.
I'm just wondering if I should keep them over the board rather than route them underneath.i figure I can't go wrong following the instructions, but figured I might as well ask.
Also, a long those lines, I remember there being a page with high quality images of the build process for the Trip Top but can't seem to find it anymore (I started this months ago but had to take a long break before getting back to it, and in that time the page was no longer there). If that still exists and someone can share that link I'd be very thankful. I believe it was an Apple photos page.
 Post subject: Re: Coax Routing
PostPosted: Mon Mar 24, 2025 3:25 am
fast food simulator
It's best to follow the instructions, as they are likely optimized for your build. Routing coax cables above the board can help avoid interference, but both over and under can work. For the build images, check forums like DIYstompboxes or the TripTop Facebook group, as they might have what you're looking for.
PostPosted: Wed Aug 06, 2025 12:49 am
I still need instructions, as they can be more accurate than trying to figure it out myself
baldi's basics
