It is currently Wed Mar 11, 2026 1:44 am
 Post subject: Trip Top Front Panel
PostPosted: Thu Feb 05, 2015 11:27 am
This is the artwork for the Trip Top front panel
Front Panel
 Post subject: Re: Trip Top Front Panel
PostPosted: Thu Feb 05, 2015 5:53 pm
Looks great! :thumbsup:
PostPosted: Fri Feb 06, 2015 10:21 am
Still wondering about the labelling. of the power switch.
Old B15 had standby switch on rear of chassis.
PostPosted: Fri Feb 06, 2015 11:31 pm
My B18 project has three switches side by side that balances the inputs, standby, ground and power, no switches on the back panel so looks like there were variations.
PostPosted: Fri Feb 06, 2015 11:59 pm
I guess something like that would work in this case too.
PostPosted: Sat Feb 07, 2015 12:12 am
Yep, the three input, six knob, three switch layout does give a symmetrical look. :thumbsup:
I can take a picture if you want.
Back panel has the fuse holder, extension amp, extension speaker and a hum control
PostPosted: Sun Feb 08, 2015 3:03 pm
This is the artwork for a two power switch scheme.
Any comments??
NEW Trip Top front panel
OLD Trip Top front panel
PostPosted: Sun Feb 08, 2015 3:08 pm
Like it :thumbsup:
Looks more balanced to me :D
PostPosted: Sun Feb 08, 2015 3:38 pm
Yes, certainly more balanced. Looking for some more input.
PostPosted: Sun Feb 08, 2015 10:07 pm
More symmetric, I like it.
Probably easier to wire, the progressive switch can be confusing to wire.
PostPosted: Sun Feb 08, 2015 10:37 pm
Another good point.
PostPosted: Wed Feb 11, 2015 8:18 pm
This is the artwork for the NEW two power switch front panel.
PostPosted: Thu Feb 19, 2015 9:15 pm
Small edit on the new design to angle off left & right side lines.
PostPosted: Mon Mar 09, 2015 6:02 pm
Queston re: Labelling of the inputs and channels.
Do you prefer
Normal and Cascade or something like NC-64 and NF-65-67
PostPosted: Tue Mar 10, 2015 9:35 pm
NC-64 and NF-65-67 might be more accurate, but seems kinda klunky. Also The NC's ran through at least part of 65, near as I can tell, as I have one. If not Normal/Cascade, maybe NC-64/NF-66? But given my whimsical/sarcastic nature, I might prefer Normal/Abnormal :)
Anyways. The reason I logged in was to ask the chassis dimensions. I am 99% certain, I'm getting one of these. As I do not have the time right now to do anything with it, I'm in no hurry. But I'm thinking to design 'double baffle' speaker boxes to sit under the head. I'm thinking to scale down the classic double baffle 15 to a 12. I would not make it a flip top. So the dimension of the head would be informative on dimensioning the speaker box(es)
PostPosted: Wed Mar 11, 2015 8:38 am
I like Normal / Cascade... It is simple and will look good.... NCxx xx NFxx xx will look like a serial number....
Andrew
PostPosted: Wed Mar 11, 2015 10:08 am
Thanks for the feedback. We will be shipping soon so you have good timing. Chassis Dimensions are 17" X 2.5" X 8"
We will be designing a 15" double baffle so if you buy the kit, we will share the cabinet design with you. Plan is to be as authentic 15 inch portaflex as possible.
PostPosted: Wed Mar 11, 2015 10:11 am
Thanks for the input. Most people understand Normal and Cascade and might not really know the amp types. I think we'll leave it as originally planned. Normal is Low Gain and Cascade is High Gain.
PostPosted: Thu Jan 25, 2018 12:51 am
jcny wrote:
My B18 project has three switches side by side that balances the inputs, standby référenceur site web Paris, ground and power, no switches on the back panel so looks like there were variations.
Well, it looks like you're badly barred. Especially with your project that may take the water if you're not careful.
