It is currently Mon May 13, 2024 11:31 pm
 Post subject: balanced output
PostPosted: Tue Oct 13, 2020 6:17 am
has anyone put a jensen out or otherwise balanced output in these?
I'm planning to add an XLR out. I'm open to suggestions.
 Post subject: Re: balanced output
PostPosted: Tue Oct 13, 2020 9:31 am
Take a look at the DI kit from DIY RE.
https://www.diyrecordingequipment.com/p ... ferrite-di
PostPosted: Tue Oct 13, 2020 9:51 am
hi Stephen,
I'm talking about putting an xlr mounted on the chassis so that there is still only one thing to plug in, and FOH or the studio can take a feed instead of micing the cabinet.
PostPosted: Tue Oct 13, 2020 10:43 am
The DI will interface with the speaker or preamp. FWIW.
PostPosted: Sat Dec 05, 2020 10:47 am
this is what I was thinking:
https://www.jensen-transformers.com/wp- ... k61-1m.pdf
or otherwise building in something so that there is a balanced line out on the back of the chassis.
PostPosted: Sat Dec 05, 2020 5:36 pm
Complicated to add two tubes to accomplish this. Should be able to do it passively like this .
You would need to add a voltage divider in front to reduce the signal.
https://nextgenguitars.ca/pages/whats-n ... -included/
Hammond 1140-DB-A
PostPosted: Sun Dec 06, 2020 6:09 pm
I was under the impression that the feed for the jensen could have been obtained from splitting the feed from the existing power tubes. is that not possible?
PostPosted: Sun Dec 06, 2020 7:19 pm
I dont think so. The power tubes need to work into the proper OT impedance. The Jensen would change that.
