It is currently Sun May 12, 2024 4:31 pm
 Post subject: Tube cage mounting
PostPosted: Sun Apr 18, 2021 7:35 pm
I haven’t found in the directions and something obvious in the kit hardware that says how to securely mount the tube protection cage. Any tips?
 Post subject: Re: Tube cage mounting
PostPosted: Mon Apr 19, 2021 4:19 pm
I found the hardware. It had fallen behind work bench. It too a magnet on a stick to retrieve it.
PostPosted: Wed Apr 21, 2021 12:25 pm
Yes, just a 1/4"threaded rod with nuts to secure it to the chassis and knurled nuts to hold it in place.
PostPosted: Fri Feb 23, 2024 12:22 am
I located the hardware. It had tumbled behind the workstation. To get it, you need a magnet on a stick.
poly track
