It is currently Mon Sep 14, 2026 6:23 am
 Post subject: TripTop specs
PostPosted: Fri Jul 28, 2023 8:52 pm
What is the current capacity of the 5v rectifier heater on the TripTop power transformer? Specifically, can I run a 5U4 or GZ37 rectifier tube which require 3 amps?
It’s been over three years and it’s still running perfectly. No bad habits or aberrant behavior. It’s a great recording amp. I’m using EL37 Mullards and a JBL D130F speaker.
 Post subject: Re: TripTop specs
PostPosted: Tue May 28, 2024 3:27 am
To determine if the TripTop power transformer can support these tubes, you need to confirm that its 5V heater winding can supply at least 3 amps of current. This information is typically found in the transformer's specifications provided by the manufacturer.
geometry dash online
PostPosted: Wed Jul 31, 2024 5:06 am
The TripTop power transformer’s 5V rectifier heater has a current capacity that generally ranges from 2 to 3 amps, which is adequate for many rectifier tubes. For a rectifier like the 5U4, which requires 3 amps, you need to confirm that the transformer's 5V winding can handle this higher current draw.
Pizza Tower
PostPosted: Thu Sep 26, 2024 4:06 am
Given that your amp has been performing well over the past three years, it seems Papa's Pizzeria likely that the transformer is adequately matched to your needs.
PostPosted: Wed Jan 08, 2025 9:18 pm
Since your amp has been functioning well for the previous three years, it seems that fnf can supply a transformer that will meet your requirements.
