It is currently Thu Jan 22, 2026 1:41 pm
PostPosted: Fri Dec 25, 2009 6:35 pm
Hey i need 4 boards, 2 designs, 2 of each board,
specs:
pre board=12.125"x2.75"
power supply board=9.75"x3.75"
I have the layouts on PDF and transfer layouts, i just need some one to make the boards with medium thickness, and don't have the equipment on hand to do it.
these boards are intended for pre-amp use, please give me an approximate quote.
Thank you
PostPosted: Fri Mar 12, 2010 12:00 pm
Did you find anyone to do this? I'd like to get some boards made up too.
PostPosted: Thu Jan 05, 2012 12:03 am
Did you guys find someone to do these pcb's?
If not I can do them on my cnc machine. I can also do custom one off faceplates.
http://www.youtube.com/watch?v=FadI53SivOg
PostPosted: Thu Jan 05, 2012 2:54 pm
What can you do for faceplates? What artwork do you need?
PostPosted: Thu Jan 05, 2012 8:20 pm
If you want logo, would need logo in a vector format, or whatever. I can get through it just that if it is in vector format re: dxf,eps,cdr then it is done in seconds. images willl take a while to trace.
for the actual faceplate, need a dimension drawing showing height, width of faceplate, hole sizes, and location and what kind of font you want and of course the text.
PostPosted: Thu Jan 05, 2012 8:30 pm
Can you 2D? 3D? Could you do a big wood nameplate with Trinity Amps carved into it?
PostPosted: Fri Jan 06, 2012 9:09 am
Sure, it does 3D really well. Here I am cutting a 3d deer scene out of wallnut.
http://www.youtube.com/watch?v=MAis-LGpkb0
PostPosted: Fri Jan 06, 2012 9:44 am
Here is an output of simulation software.
PostPosted: Fri Jan 06, 2012 3:54 pm
Oh, I'm really liking that!!
