It is currently Sat Dec 13, 2025 4:13 pm
PostPosted: Sun Jan 31, 2010 6:06 pm
Bad luck has struck (yet again, im getting sick of this!) on the job front and I need to abandon an 18w project I was in the middle of.
The following items are for sale for an as-is project:
* Custom 16"x8"x2.5" chassis
* Heyboer 18w power and Output transformer set
* VVR cathode bias kit
* Completed/populated turret board
* All hardware (standoffs), switches (impedance, power, standby), fuses, IEC, cliff jacks, pots, bayonet lamp that you will need to get the amp up and running
* 7 fender barrel style knobs
* enough 22-ga teflon wire for 3 amps
* 4 russian military-spec EL84s
* 4 russian military-spec EF86s
* 2 sovtek 12AX7s
* 1 NOS EZ81 rectifier tubes
* Mouser grab bag of components to complete the amp
Pictures of everything is available upon request.....
Like I said, the above list of items is everything you'll need (right down to the tubes) to get a working 18 watt going. The only item you will need are faceplates (and I will gladly provide you with corel draw files that exactly match the holes on this amp chassis so you can get one made)
Let me stress that one factor here is that this isn't a traditional 18watt setup layout. My layout, for my board, is slightly different, and you will need to be experienced enough to figure it out and take it from there. I'm not going to be in a capacity to walk a newbie builder through this.
Anyway....I've got well over $500 of parts into this.
$350 + actual shipping to you
If interested, email me at fmb15@verizon.net
