If you mean the connections from the copper ground rail to the turrets themselves, it doesn't make a difference as long as you don't inadvertantly ground out something. It's a matter of preference, some people use wire with stripped ends to run the connections, hence the insulation while others use scrap wires or lead trimmings from resistors/capacitors to be frugal
The boost acts like a boost pedal, the resistors go in parallel (hence lower equivelent resistance) and I believe the cap passes some highs through, theresfore a hotter brighter signal. (Someone please correct me if I got something mixed up).
I think it's a useful addition just to see how you like it.
The resistor is a matter of choice, some feel that the carbon comp adds some "mojo" and warmth to the signal, others say that the carbon comp just adds hiss and a higher noise floor and use the metal film, again a personnal toss-up decision.
Hope this helps, sorry I don't have pictures of my builds but if you search for something like "build notes" or "my build" you may (should) be able to find threads on these forums to help.
