zaphod wrote:
Bigfoot wrote:
when I am playing the amp pretty much dimed (on either channel), the cruchy chords/rhythm are all there and sound pretty fantastic, but when I play some lead licks there is this funny overtone to the sound that, and here comes my best description, sounds like I am playing through a phase pedal or something. It is particularly noticeable when I play a single note and hold it, then add some vibrato to it -- definite phase sound.
Emohawk wrote:
So, I'd recommend some chopsticking. I suspect it's some sort of interference caused by the wrong wires being a tad too close, exacerbated when EL84's (or EL34's) are running hard.
Yes, it could be some high frequency oscillation creeping in when the amp is being cranked, in which case chop-sticking, judicious use of shielded wire and twisting OT connections may help. It could also be caused by a bad filter cap. And you could try installing a Zobel filter on the OT secondary to reduce the speaker impedance peak in the high frequency range which causes an impedance mismatch at high frequencies, particularly affecting the performance of EL84s and to some extent EL34s (both are pentodes). A 10ohm 5W resistor in series with a 2uF non-polarised cap across the OT secondary has been reported to give good results. Alternatively, just think of it as a cool built-in effect.
I hear ya on the cool built-in effect, but i would prefer a pedal to provide the effect than the amp.
Sorry to be a pest, but could you "dumb it down" a bit for me:
Chopsticking -- I know generally what this is, but could you clarify for me exactly what it is? Do I just take a stick and touch all wires, components, tube pins, etc. until I hear a change in sound? Also, for my problem, I assume I would do the chopsticking with the amp dimed?
Zobel filter -- if possible, could you draw the mod on a schematic for me? Or at least clarify what the "OT secondary" is?
I am an accountant by trade so I definitely struggle a bit when I need to troubleshoot one of my projects. I am ecstatic that my amp works and sounds really pretty good -- I would like to figure out this "phase" issue though.
Stephen/Coco -- do you have any thoughts on my two issues that you could contribute?
Thanks everyone!!
Bigfoot
