It is currently Wed May 14, 2025 12:50 am
 Post subject: PT wiring question
PostPosted: Sat Mar 14, 2015 1:15 pm
I bought years ago a TMB kit and now I finally have time to really work on it.
I am confused about the wiring to the rectifier tube heaters. On the layout it says 3.2V and 3.2V to pins 4 and 5, and 5V tie off.
If you look at the PT photo, it says 6.3, 5.0 and 0. There is no 3.2. Should I go with 6.3 and 5.0 to pins 4 and 5, and go to ground with 0?
 Post subject: Re: PT wiring question
PostPosted: Sat Mar 14, 2015 5:54 pm
Use the 0 and 6.3
Tie off the 5V
PostPosted: Sat Mar 14, 2015 6:41 pm
Use the 0 and 6.3
Tie off the 5V
Thanks. Does it make any difference what pin the 6.3 and 0 wires go to? Are they interchangeable?
PostPosted: Sat Mar 14, 2015 8:33 pm
nick wrote:
Use the 0 and 6.3
Tie off the 5V
AC so it does not matter
