I implemented the Ruby mod, which nearly removed all of the crossover distortion. Because the highest cathode voltage I had recorded was about 25.5 VDC, I went with a 3 diode array: 20V and 6.5V zener in series (both 5 Watt) and back to back with a 1n4007. That was connected in parallel with each 220K grid leak resistor with the 1n4007 side going to ground. Some pics of both channels on my scope. This was the most prevalent I could make the crossover distortion with a SS rectifier. It is even less apparent with the 5AR4. Sounds much better now.
I then installed the VRM and tested it. All good. But I did not have time to rewire the input jacks and V1 socket. So, I'll be tackling that next weekend. And then tidying things up in the amp with zip ties and thread lock, etc. I plan to play the amp for a week at least after that before doing any other mods.
I am still considering reworking the amp to incorporate GNFB similar to what a real plexi would have. That requires several changes: channel mixing resistors and moving both channels to 1 input on the phase inverter, changing the tail resistor, adding the NFB resistor and feedback tail resistor, and phase inverter plates. Or if I don't do that, I may try to make the gain range more usable on the plexi channel. Maybe I'll be happy with it and leave it as is. Who knows....
I'll try to grab a short audio clip next week.
-Dan
