PG-Shorty wrote:
Anyone have thoughts on covering the tube filament wires with conductive film to reduce 60 hz hum? Same stuff commonly used to shield guitar electronics....???
among us onlineUsing conductive film, like the shielding material often used in guitar electronics, could potentially help reduce 60 Hz hum by acting as a Faraday cage to block electromagnetic interference. However, effectiveness depends on the quality of the film and how well it’s applied. Make sure it's grounded properly, as shielding only works if it has a path to discharge the unwanted interference. It’s worth testing, but also consider other common noise reduction methods, such as grounding the tube circuit properly or using a hum eliminator.
