It is currently Wed Mar 12, 2025 12:36 am
PostPosted: Sun May 01, 2005 2:28 pm
I received an s2 18watt output transformer on Friday. I finally got it installed and gave it a quick test drive this morning. I can't remember what anyone has said about it (other than s2 worked hard to create it) so I am testing blind in a way. Also, for reference sake, my Trinity 18 is equipped with a Heyboer transformer set shipped directly from GDS. I have been playing that amp almost every day for about 3 months. For these test I was driving a Bognor Shiva style 1x12 with a vintage 30 in it. The guitar was a historic '57 les paul custom with '57 classics in it.
Quick Summary.
Complex mids
Fast response to picked notes
Tighter Bass (Especially in the TMB channel
Better clean tones.
More harmonic overtones on held notes and chords.
Detailed Report.
So, I started my test in the normal channel. I immediately noticed a more complex midrange response and clarity. There was more grind in the normal channel than with the Heyboer. I don't know if these are the same thing but they were both there. The complex mids and clarity allowed me to play stuff like Stone Temple Pilots with great results. If you have ever tried to play major 7th chord in distortion mode you will know that it doesn't always work with all amps. It wasn't bad before but it is noticeably better now.
In terms of faster response, the notes just seemed to jump out of the speaker with a nice pop on the leading edge. The pop is that percussive note attack that I remember hearing from 100 watt plexi's. I like that. The really cool thing is it can be controlled with pick attack and palm muting. Can't stop the pop!
Tighter bass!!!
This was a very pleasant surprise. With the Heyboer, in the TMB channel I had to keep bass <3-4 to keep the channel from sounding muddy and loosing definition. The response of the s2OT was such that the bottom end is much more focused than before. No need for a 250M pot to try and trim back the bass. Not sure yet but the top end seemed less harsh too. I NEVER have the TMB treble above 5 but had it maxed and was loving it.!!!!
Better Cleans.
Clean sounds from an 18 watt? Well, previously the clean sounds were a little flat with no real sparkle in the sound. It was ok but a little lifeless compared with the cleans on other amps. With the s2OT the normal channel really came to life for clean sounds. Even with a les paul the sounds had more 3d qualities than before. Considering clean sounds are not the forte of this design it was a pleasant surprise. Because of this and the more complex mids, the range of tones available from the Normal channel just went up 2 fold.
Harmonic Overtones.
My favourite topic. I love my two rock opal because you hit a note, order a beer, and when you come back the note has bloomed into a higher harmonic. The Trinity 18 now has more of that quality than it ever had with the Heyboer OT. I was a little surprised when I hit two notes and within seconds had a different harmonics just jumping out of the amp. They were there before but now! Oh Boy! This is very cool and usually only found in the most responsive and finely tuned amps (like my Two Rock Opal (costing $4k) which does this even at bedroom levels).
Summary
I still have a bunch of A/B testing to do but my fist impression is thumbs up. My least favourite qualities of the 18 watt design have been mitigated and my most favourite have been enhanced. The amp has enhanced clarity, focus and complexity that didn’t come through with the old transformer. For me this is a keeper.!!!!!!!
PostPosted: Sun May 01, 2005 3:15 pm
My 18watt lite II has one of steve's s2 trannies.
Can't comment about the Heyboer's, since I've never heard one...but the s2 sounds great from my end!
-F
PostPosted: Mon May 02, 2005 12:32 am
S2, want to trade a Heyboeur OT for one of yours? :-)
Bob
PostPosted: Sat May 14, 2005 1:32 am
The s2 tranny is permanently mounted in my amp now.
I will be doing some clips this weekend of the Trinity 18 with the s2 output tranny. There will be lots of rock and roll in there played on various single and humbucking guitars. I will put a link in here when I post 'em.
lbet
PostPosted: Sun May 15, 2005 12:17 am
As promised, here are a couple of clips of the s2 Transformer in the Trinity 18 Watt TMB.
The first is the normal channel with volume on 6 tone on 10.
The second is a 12 bar blues thing. Once again normal channel with the Volume on 10 and the tone on 1. It is one of my fav settings on this channel.
Salute
12 Bar
Also here is a link to the comments on the 18 Watt site. The same clips are posted there.
s2 Output Transformer; Sound Clips
PostPosted: Mon May 22, 2023 3:43 am
It's great to hear that you're pleased with the results of installing the S2 18-watt output transformer in your Trinity 18 amplifier! It sounds like the transformer has brought about several positive changes in the amp's performance.
The complex midrange response and increased clarity you mentioned can contribute to a more articulate and defined tone, allowing you to achieve better results when playing different styles of music, including more intricate chords and harmonies.
rankdle
PostPosted: Thu May 09, 2024 4:06 am
It seems like the S2 transformer has truly enhanced the clarity, focus, and complexity fnaf of your amp's sound, making it a keeper in your book.
PostPosted: Sat May 25, 2024 6:53 am
It's wonderful to hear that you're thrilled with the results after installing the S2 18-watt output transformer in your Trinity 18 amplifier! It seems the transformer has significantly enhanced the amp's performance. The improved midrange complexity and increased clarity you've noted can lead to a more articulate and defined tone, allowing for better expression across various music styles. This upgrade is particularly beneficial for playing intricate chords and harmonies, giving you greater versatility and precision in your sound.
PostPosted: Tue Feb 11, 2025 10:23 pm
lbethune wrote:
I received an s2 18watt output transformer on Friday. I finally got it installed and gave it a quick test drive this morning. I can't remember what anyone has said about it (other than s2 worked hard to create it) so I am testing blind in a way. Also, for reference sake, my Trinity 18 is equipped with a Heyboer transformer set shipped directly from GDS. I have been playing that amp almost every day for about 3 months. For these test I was driving a Bognor Shiva style 1x12 with a bitlife vintage 30 in it. The guitar was a historic '57 les paul custom with '57 classics in it.
Sounds like the s2 OT really brings out the best in your 18-watt! The improved clarity, tighter bass, and harmonic richness make it a worthwhile upgrade. Looking forward to your A/B comparisons—enjoy the tone!
PostPosted: Wed Feb 12, 2025 4:27 pm
Hate to be a stick in the mud but ...
This reminds me of when I built my first SE amp using a Hammond 125SE Universal OT. There was an option to upgrade to a Heyboer OT instead. Many on the AX84 user forum claimed it to be superior, clearer, better lows, less muddy etc. etc. etc. I ordered it, paid the import duties, connected it up .. shaking with anticipation and..... no audible difference. The lowly Canadian made Hammond was every bit as good .. perhaps even better.
The only way to be objective about this is record the signal with a looper pedal and then setup your mic .. position it in front of your speaker and don't move it until all recording is complete with exact same settings of vol/tone controls and DAW settings for both OT's and no post processing. Then post the results. After that I may believe you. If you convince me I will have to eat my hat and replace my Heyboer with the S2.
I've heard comparisons of Mercury vs Heyboer vs Hammond for different amps done this way and differences in the recordings were surprisingly minimal and very subjective as to which one was better if at all. Any differences could have been due to mics being moved, pot settings not exactly the same etc. Plenty of comments like the Mercury was soooo much clearer, fuller etc... typical pre-conceived bias, but I just couldn't hear it in the recordings.
PostPosted: Wed Feb 26, 2025 2:38 am
The only way to be objective about this is record the signal with a looper pedal and then setup your mic .. position it in front of your speaker and don't move it until all recording is complete with exact same settings of vol/tone controls and DAW settings for both OT's and no post processing. Then post the results. After that I may believe you. If you convince me I will have to eat my hat and replace my Heyboer with the S2. Incredibox
You make a very reasonable and factual argument! When it comes to audio components, especially output transformers (OTs), more factors can affect perception than actual differences. I completely agree that rigorous A/B testing is necessary to eliminate subjective bias. How many people do you think take the time to do these comparisons before concluding?
