It is currently Tue Dec 02, 2025 12:30 am
PostPosted: Tue Sep 17, 2013 10:53 pm
So I am building an 18Watt Plexi with the 6v6 option
This is my first Trinity kit but have built other amps.
I am pretty much following the schematic. I am using my own wire
for some areas other than that pretty much using all the parts that came
with the kit.
So here is the turret board almost finished, have not decided yet how I am going to do the bus wire
PostPosted: Tue Sep 17, 2013 11:00 pm
Some chassis shots
PostPosted: Sat Sep 21, 2013 11:02 pm
Excellent job on those heater wires.
For the buss, I take a piece of solid correct 22 ga, solder it at one end, stretch it to the other end and solder it in place. Makes a nice straight line.
PostPosted: Wed Jun 18, 2025 5:44 am
with the kit.
Pokémon Gamma Emerald
What type of wire do you plan to use for the bus wire?
PostPosted: Tue Jul 15, 2025 6:30 am
with the kit.
Imagecrossy road
If interference is a concern, try grounding so that all connections are to a single point.
