It is currently Tue Aug 04, 2026 4:48 am
 Post subject: 18W Tremolo Volume Drop
PostPosted: Sat Jul 18, 2026 5:40 am
Has anyone noticed a noticeable volume drop when switching the tremolo channel on an 18W build compared to the normal channel, even after matching the control settings? I'm trying to figure out whether this is a normal characteristic of the circuit or if it usually points to a component value or wiring issue. What was the cause in your case?
Retro Bowl
PostPosted: Tue Jul 28, 2026 3:29 am
lyly19 wrote:
Has anyone noticed a noticeable volume drop when switching the tremolo channel on an 18W build compared to the normal channel, even after matching the control settings? I'm trying to figure out whether this is a normal characteristic of the circuit or if it usually points to a component Meowdoku value or wiring issue. What was the cause in your case?
It's always helpful to see detailed discussions and practical advice from experienced amp builders. These kinds of community conversations are a great resource for anyone working on DIY tube amplifier projects.
