It is currently Tue Jul 16, 2024 1:47 pm
 Post subject: Tighten up an sIII plexi
PostPosted: Fri Feb 29, 2008 7:28 pm
Hi, Have an sIII that i switched to the sIII plexi values as per the layout stickyed (sp). However, both channels are a bit muddy now with hb's after midway or so. Looking for TIGHT grind and crunch up the dial. Any suggestions? Thanks in advance.
PostPosted: Fri Feb 29, 2008 8:54 pm
Haven't had that comment before. Drop the output tubes cathode bypass cap to 25-50uf / 50V
PostPosted: Sat Mar 01, 2008 9:23 pm
I just (this afternoon) swapped out the three caps to change my TMB side of my sIII into a "plexi"...
There is a very noticeable difference in tone, more chimy-grind if thatmakes sense. I will need to play with it for a while but from first impressions I think I like it a lot! I left the right hand side alone.
AJC
PostPosted: Sun Mar 02, 2008 10:47 am
AJC
I found it really cuts through the mix on stage as well.
