It is currently Tue Jul 16, 2024 12:39 pm
Post new topic Reply to topic  [ 182 posts ]  Go to page Previous  1 ... 6, 7, 8, 9, 10  Next
PostPosted: Sat Jun 02, 2007 4:34 pm
So you know, this was the switch over amp. where they finally decided to allow rock and roll. The amp has 6L6 tubes. Right now I have my RCA 6l6's in her. I wasn't going to include them in the sale. But.... one never knows.
The trannys are HUGE and clean as a whistle. as is the amp. She is heavy.
:D :D Are you drooling yet :lol:
Forgot, she is , of course, all original.
Coco, can you please switch this over to the Want ads.
Thank you,
Later,
Jac
PostPosted: Sat Jun 02, 2007 10:00 pm
Okay, the next step is do I try out the Celestion Vintage 30 the Eminence, or just throw the Jenson in. Damn the choice is tough.. What's 1st :? :? :D
PostPosted: Sun Jun 03, 2007 12:14 am
UUhhmmmm Marshall!!!! :roll:
Vintage 30 of course!!! :lol:
Let's hear her.
LeeMo
PostPosted: Sun Jun 03, 2007 12:32 am
Boy, You guys Now remember the Trinity is designed to be cleaner then the normal 18watt. But I guess I'll through the Celestion in, Geez it's tough but someone has to do it.
Of course the Celestion is the hardest to get too :lol: :lol:
PostPosted: Sun Jun 03, 2007 12:33 am
hopefully tomorrow I'll record my 1st ever clips. This is great, I'm having a ball. :D :D
PostPosted: Sun Jun 03, 2007 7:26 pm
Good to hear you got there with your sIII Jac :D and look forward to the clips - I know your going to inspire me to finish mine. Now, I must get back to this Hi-Lo Deluxeish thing I'm working on before I get sidetracked!
PostPosted: Sun Jun 03, 2007 11:20 pm
jac,
Plug a humbucker equipted axe into the normal channel cranked to eleven and tell me that again with a straight face. I dare ya. :lol:
LeeMo
PostPosted: Mon Jun 04, 2007 10:50 am
jac wrote:
WE HAVE IGNITION! :D :D :D :D :D :D
Jac - congrats! I've been away for a few days. So nice to come back to good news likethis!!
Loking forward to your clips!!
PostPosted: Mon Jun 04, 2007 3:53 pm
Okay guys,
It was nice while it lasted.
Could not find the screws, damn move, so went out and bought some. Speakers hooked in She's playing. the sIII channel goes down in 30 seconds.
So.... I've been studying everything trying to figure out wtf :shock:
I've been looking at your troubleshoot thread and I came up with this. Now I have not implemented anything yet.:
1st I had popping at 1 point. Now I just have nothing. Ya think I have 1 of those 500pf bad caps?
2nd here's an important one. I wired the .0047uf from the tone pot on the Normal channel to the bus bar according to the color layout.
Now, according to your troubleshooting thread and your 11 x 17 non-color layout. I should have wired the .0047 to the tone and volume pot :shock:
What's up with this? would either of these be cause for the sIII channel to shut down. Am I supposed to change this ? :?
PostPosted: Mon Jun 04, 2007 4:45 pm
Nothing on the Tone/Vol of the Normal channel should impact the sIII. That bad 500pf cap would probalby not cause a total loss of volume.
Is the normal channel still working? If so, try an altternate V2.
If not, check things again you dont want to blow an OT! :shock:
Voltage measurements??
PostPosted: Mon Jun 04, 2007 5:17 pm
No!
The normal channel's working.
It's the sIII that keeps dying. What about the .0047 tha t is attached differently from your troubleshooting?
Should I change it?
PostPosted: Mon Jun 04, 2007 6:18 pm
jac wrote:
What about the .0047 tha t is attached differently from your troubleshooting? Should I change it?
Thats on the Normal channel. For that I just changed the location of the ground. No effect on the sIII channel.
Sounds like a solder connection. Get out the chopsticks and touch all the connecting the sIII channel, hoping you'll get a noise when a bad connection is touched.
Try another tube in V2. What are the voltages on v2 - are they close to spec? Is the other half of V1 OK?
The PI is apparently working so it should be V1 or V2 &/or sIII channel circuitry.
PostPosted: Tue Jun 05, 2007 12:00 am
Yes, I realize that the PI is working.
PostPosted: Tue Jun 05, 2007 7:39 am
Voltages:
no tubes:
EZ81: P1&7 - 429.4VAC
HEATER WIRES: 3.26 for each wire
3.21 for all filaments
with recto in:
EZ81: P1&7 - 308.0 VAC
B+: 308.0 V
V1-V3: P1&6 - 42.2 VDC
V4-V5: P7 - 42.1VDC
with tubes in:
V4 - P3: 11.6/ P7 - 333.5/ P9 - 330.9
V5 - P3: 17.8/ P7 - 337.6/ P9 - 331.2
testing preamp, but touching pins 1&6 on V3 cause's major hum the minute you touch the probe.
I'll put the results up in a few.
btw, all volts measured VDC
1= 145.7
3= .933
6= 151.2
8= .152.2
*V2*
1= 163.4
3= 1.08
6= 257.0
8= 162.6
*V3*
1= 190.3
3= 190.6
6= 178.3
8= .86
PostPosted: Tue Jun 05, 2007 4:32 pm
Found the problem in the PI Go figure. So much for working. The chopstick found it. Forgot to do this. What an airhead.
Now how do I fix?
PostPosted: Tue Jun 05, 2007 9:23 pm
jac,
My PI V3 is as follows :
1=205.8
2=45.3
3=67.1
6=206.8
7=45.8
8=67.2
LeeMo
PostPosted: Tue Jun 05, 2007 9:38 pm
jac,
did you use the jumper from pin 3 to pin 8 ?The voltages should be almost exactly the same.
viewtopic.php?t=752&start=0&postdays=0&postorder=asc&highlight=
Look at the forth pic from the top. There's an orange jumper from pin 3 to pin 8.
LeeMo
PostPosted: Wed Jun 06, 2007 11:09 am
have to pull board, but I'm pretty sure that's okay. The problem is @pin 7 V3 to that turret and then including the .01uf lead. stops after that. Voltages are definitely off there
PostPosted: Wed Jun 06, 2007 1:23 pm
Oh boy, be sure you need to pull that bord out before you do!! Not much fun. :(
PostPosted: Wed Jun 06, 2007 1:39 pm
I know :shock: :shock: :shock: I don't want too, but I think it's necessary. I'm thinking when I refloated all the turrets that something dropped out or disconnected.
That line shouldn't be microphonic like that. and I can't see anything on the surface.
Oh well, sucks to be me. But I'll keep trying.
On another note. I got 1 of the 1st of 5 old stereo's promised to me.
It's a beauty Dual 6AQ5A, 6x4 and a 12AX7A, Very nice. also has balance tone volume treble with concentric Carling pots . Sprague caps and 3 OT's (5 speaker system) :shock: Change some caps add a OT. The chassis' great. Plenty of room. Add a shell.
Free cool guitar amp :D :D :D Nice
