It is currently Tue Jul 16, 2024 11:15 pm
Post new topic Reply to topic  [ 24 posts ]  Go to page Previous  1, 2
PostPosted: Tue Oct 12, 2010 2:38 am
Hey guys, been lurking here for awhile. I have a plexi v6 mid boost 1x12 combo(cream and black tolex) with a Heritage G12H-55 that I have decided to dedicate to 6v6s only. I just find myself using them more than the EL84s. Zaphod what exactly needs to be modded to get the most out of the 6v6s? I'm currently running JJ's version which seem to suit me well so far.
Thanks...
PostPosted: Tue Oct 12, 2010 11:47 pm
Just purely for the 6V6s, the PI's tail and cathode resistors need to be changed from 56k/820 too 20k/470. This will help get more drive to the 6V6s, which have a lot less gain than EL84s. If your amp is a more recent Trinity Plexi, it may already have the 470 ohm in there, rather than the more usual Marshall 18W's 820 ohms.
The question then is how to reduce the drivel level for the EL84s, so they don't start crapping out tone-wise. So here's what you end up doing, if you want to run both 6V6s and EL84s optimally. Instead of both sets of tubes using 470k grid reference resistors, you split each 470k into a 220k and a 250k, connected in series. So you end up with a 220k+250k (=470k) on each side. You connect each EL84's grid to the junction of it's respective 220k/250k pair, so that it's fed an attenuated version of the PI drive signal. The 6V6s are connected as before, to the top of the 220k+250k pair, via an 8.2k grid blocking resistor, just as if it was a regular 18W amp. I hope that makes some sense. It's actually simpler to do than to describe.
PostPosted: Tue Oct 19, 2010 2:36 pm
Thanks! I will get in there and swap those PI values in. I am only interested in running the 6v6s at this time. It's nice to have the option with the el84s but I just don't use them with this amp. We'll see how she goes! This is my second 18watter, first one was a GDS stock 1974 clone. I picked this one up at a time when I was about to build the v6 kit and there happened to be this one for sale. Kudos to the previous owner who built it, very neat with excellent lead dress/solder joints.
Cheers all.
PostPosted: Tue Oct 19, 2010 8:59 pm
Check out the clips of this 6V6 18W with the tweaked PI values
http://www.youtube.com/watch?v=n4pU7cMu4TM
Users browsing this forum: Google [Bot] and 29 guests
