It is currently Wed Mar 04, 2026 9:23 am
Post new topic Reply to topic  [ 30 posts ]  Go to page Previous  1, 2
 Post subject: Re: VRM Installation?
PostPosted: Thu May 10, 2018 1:35 pm
Hello. I have noticed the R3 was increased to 220K. (Used to be 100K, wasnt it?). The thing is I want to reduce volume just a little more when pot is on zero. (I believe I have R3=100K in my amp). Shall I put another 100K across it?? Thanks!
PostPosted: Fri May 11, 2018 9:21 am
No, leave it. The resistor just sets the lowest threshold. No worries.
PostPosted: Fri May 11, 2018 10:08 am
What resistor should I reduce then so I can achieve a lower volume when VRM pot is on zero?
PostPosted: Fri May 11, 2018 10:50 pm
That would be the one, but it seems very extreme to go lower than 100K. Well, If you do put another 100K in parallel, you will drop the lower voltage even further and also the volume.
PostPosted: Mon May 14, 2018 9:06 am
Thanks Stephen!
Would probably try 82K or someting like that!
PostPosted: Tue May 22, 2018 10:57 am
I finally tried a value around 60K, and It sound right for me!! I like it.
It this value extremely low? Voltage drop is too high?
PostPosted: Tue Jul 17, 2018 4:02 am
never thought about it in terms of a heat sink.
PostPosted: Sun Jul 22, 2018 3:11 pm
How is it behaving?
PostPosted: Tue Dec 03, 2019 3:58 pm
How is it behaving?
Perfectly well!
PostPosted: Thu Dec 05, 2019 8:56 am
Thanks for trying it out!
