Post new topic Reply to topic  [ 23 posts ]  Go to page Previous  1, 2
PostPosted: Thu Mar 02, 2006 10:43 pm
I have some Electro Harmonix in the shop over here if you want to bring it by & try them out. You can buy them if you want.
PostPosted: Fri Mar 03, 2006 3:39 pm
Low and behold you were correct.
Put in a fresh set of JJs out of a box today (3 preamp tubes only) and viola... feedback issues have disappeared; in fact the amp sounds fantastic (was able to try it out at lunch today)
Thanks for the idea and help; guess I should have thought of that myself :roll:
Bought them at Songbird... guess I could try the EH's that you suggest but these sounds pretty good to me for now
Once again, THANKS!!!
PostPosted: Fri Mar 03, 2006 10:22 pm
You should try just one JJ in V3 (in your amp its the one the Master Volume is connected to). This would most likely be the suspect tube. Then you can save your JJs if you want. I doubt they were all bad.
