It is currently Wed Mar 04, 2026 10:52 am
Post new topic Reply to topic  [ 45 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: New Plexi Build
PostPosted: Fri Sep 21, 2012 5:59 pm
ezcomes wrote:
is the Bias switch to run the 6v6's?
what is the purpose between the two 1R resistors going to V4 and V5?
The bias switch is for selecting cathode or fixed bias. (fixed bias has more components than the original cathode bias thats in a stock 18 watt and trinity build)
The two 1R resistors are for taking voltage measurements when setting up fixed bias
You might also want to read through this post
http://www.trinityamps.com/phpbb/viewtopic.php?f=7&t=2622
PostPosted: Sat Sep 22, 2012 9:16 am
Haha yea...realized that after i posted...came across this thread via google
PostPosted: Fri Jan 24, 2014 9:34 am
Unimind wrote:
What type of cab/speakers are you using in that clip??
It's an old Peavey cab with 200 watt Scorpions at 4 ohms.
I have always loved this cab and speakers. I have had many cabs over the years but this one always sounded the best to me.
Would those be Peavey Scorpion S-12825 12" Speaker Drivers ?
Thinking of making a 212 for a Customer who wants to emulate that tone!
PostPosted: Mon Mar 31, 2014 11:37 am
zaphod wrote:
I wonder if your PV speakers are anything like the Celestion Lead 80 - http://professional.celestion.com/guita ... l.asp?ID=8 Do you have any PV specs to compare against?
I found this: http://www.loudspeakersplus.com/product ... N-SP-1225/ I have the 4 ohm version from 1978 but that is the speaker I have.
Edit: I notice that this speaker has a lower freq response than any Celestion. Usable freq. range: 60 Hz ~ 4 kHz
Here is some more info http://www.peavey.com/media/pdf/manuals ... series.pdf
Les
PostPosted: Wed Apr 02, 2014 8:28 am
Thanks. I will check them out!
