It is currently Tue Dec 02, 2025 5:42 pm
 Post subject: V6 as an acoustic amp
PostPosted: Sat Aug 18, 2007 4:22 pm
So , today I mounted some Piezos under the ridge of my Taylor GS as per the instructions on the K&K pickup site. I had to try it out, so I plugged her into the TMB channel on my V6 Trinity. I put the Master on 10, the Vol on 2, the Bass on 10, the Mid on 8 , and the Treb on 9. Thru my Bluedog alnico and my 1230-55 ceramic BBQ speakers.
To my poor tired ears it came thru pretty good. Oh yeah, I used the "Boost" and the EL84's.
LeeMo
PostPosted: Sun Aug 19, 2007 12:04 am
Hi LeeMo, I often use the Ovation through the sIII, it gives a brilliant sound.
Nigel
PostPosted: Sun Aug 19, 2007 11:14 am
I'll have to try that out too. Sounds interesting. I guess it wasn't acoustic clean though.
PostPosted: Sun Aug 19, 2007 3:07 pm
With the master down low it is pretty clean. The peizo quackiness is compressed somewhat by the tubes. The boost adds gain and treble, or so it seems.
LeeMo
PostPosted: Sun Aug 19, 2007 4:23 pm
LeeMo
Do you mean the Master @ Max and the Vol low.
Boost adds both, but the 22uf lets a lot of broad band gain into the mix. Tighten the gain bandwidth up with a lower value.
PostPosted: Sun Aug 19, 2007 4:48 pm
Yep, my bad. :oops:
LeeMo
