It is currently Tue Jul 16, 2024 1:46 pm
 Post subject: big yellow resistor?
PostPosted: Sat Nov 10, 2007 11:19 am
on some of the s111 board layout and pics there is a giant cap/resistor on the right hand side of the board with the markings 'etr met 105k 630v' what is it and why is it only on some of the boards?
PostPosted: Sun Nov 11, 2007 6:15 pm
it's a 1uf 630v cap
check here for more on reading caps: http://www.wescomponents.com/capacitor/
105k meaning 10 with a multiplier of 100,000 with the k representing 10%+- tolerances.
the first two digits times the third (5 representing the number of zero's; hence 100,000.
Edit - From what i have seen this is typically a 684k cap (68 times 10,000 = .68uf.) On the layout Stephen has a .62uf cap. Perhaps he just uses what he can get his hands on?
Edit 2 - After more research I have found that the higher that value on the cap the fatter the tone ofthe TMB channel. On the mods list Stephen says that if you want to try for a fatter sound you can try a 2.2uf in there.
PostPosted: Sun Nov 11, 2007 8:59 pm
thank you very much. now it make sense why some pics have it and some dont. sure is a big component.
PostPosted: Mon Nov 12, 2007 8:41 pm
Schematics / layout use 0.68uf or 684K (K is the tolerance).
viewtopic.php?t=689
It is fat because it's a Metalized Polyester Film cap, not a polarized electrolytic.
Here's a value chart you might find useful:
http://www.sozoamplification.com/chart.html
