I've also considered swapping to 36 watt trannies and running both pairs of tubes tpgether. I understand that you get the best of both , creamy smooth clean bottom from the 6v6 and glassy highs from the EL84's.
LeeMo
Did you ever try this? Maybe a switch scheme could be made so that el84, 6v6 or both could be selected? Would be cool...For now I'm settled with 18 watt but I have the vvr/vrm and the existing trannys could be used for a tc-15...
Edit: Now realise this might need a different rectifier aswell. The purpose would be a bit more clean headroom, but I can use my other amp for loud clean tones. More rocking less thinking
