It is currently Tue Jul 16, 2024 4:04 pm
 Post subject: 6v6 or el84 or both
PostPosted: Thu Aug 07, 2008 2:51 pm
I've also considered swapping to 36 watt trannies and running both pairs of tubes tpgether. I understand that you get the best of both , creamy smooth clean bottom from the 6v6 and glassy highs from the EL84's.
LeeMo
Did you ever try this? Maybe a switch scheme could be made so that el84, 6v6 or both could be selected? Would be cool...For now I'm settled with 18 watt but I have the vvr/vrm and the existing trannys could be used for a tc-15... :hmmm: :bugeye:
Edit: Now realise this might need a different rectifier aswell. The purpose would be a bit more clean headroom, but I can use my other amp for loud clean tones. More rocking less thinking 8)
PostPosted: Sun Aug 10, 2008 1:40 pm
It would be hard to run and EL84 & 6V6 together. you cant run all at thesame time because of the OT impedance. you might be able to mix a 6V6 & EL84 but I'm unsure if you could hear the difference.
Easier to switch one set in & one set out.
