It is currently Tue Jul 16, 2024 4:14 pm
PostPosted: Sat Sep 20, 2008 10:53 am
..... into a 23" wide head cab. I have a Reinhardt 2x12 and I'd like to build my own head kit to save a good chunk o' change but it'd have to fit on the cab. How much extra $ does a custom sized head cab cost over what Stephen has listed?
Thanks all
Stew
PostPosted: Sat Sep 20, 2008 12:07 pm
The chassis itself is 20" wide, and you would ideally need some space to "overlap" the front panel for cosmetic purposes. Technically it would fit with some creativity. For a custom cab you'll need to talk to the big guy or roll your own :D
Joe G
Some assembly required,
Brain sold separately...
PostPosted: Sat Sep 20, 2008 12:41 pm
The answer is Yes. Curent head cab is 22" wide! Sounds like a perfect fit to me!
PostPosted: Sat Sep 20, 2008 12:52 pm
:shock: Cool!!! I don't know why.. but I always thought the head cabs were a lot wider than that.
now...plexi,sIII or TMB .. :?: ..I'll be in touch.
Stew
PostPosted: Sat Sep 20, 2008 12:55 pm
JCM 800s are 30"; Most original 18 heads were 24" but we shortened it up to 22" to make it look better. Some plexis are 26"
