It is currently Tue Jul 16, 2024 7:35 pm
PostPosted: Thu Jan 15, 2009 3:05 pm
hello
just finish to build today : it work so good
very good clean and break up well
but the crunch seems to be cripy and flappy on the tmb chanel
tried different tubes and different cabs
any ideas ?
thx
 Post subject: Re: new plexi
PostPosted: Thu Jan 15, 2009 4:50 pm
You can use a 25 uf 50V on the cathode bypass cap for the power tube. How does the Normal channel sound?
PostPosted: Fri Jan 16, 2009 7:00 am
very good with good harmonics
PostPosted: Fri Jan 16, 2009 7:52 am
Then the 25 uf cathode bypass cap may not help you. It's interesting because the normal channel has a 220uf bypass cap on the pre-amp and it has a lot more bass content in it. Yuo are using .68 in V1 for the TMB channel?
PostPosted: Fri Jan 16, 2009 8:00 am
yes 68 K
i just see your board in the builder guide section :capacitor polarity seems to be bad on my board :!:
PostPosted: Fri Jan 16, 2009 10:14 am
here my voltage :
AC 235 VAC
B+ with tubes 333 VDC
V1
p1: 137
p3:0,85
p6:135
p8:0,9
V2
p1:150
p3:1
p6:180
p8:151
V3
p1:180
p2:52
p3:80
p6:180
p7:52
p8:80
V4
p3:12
p7:319
p9:303
V5
p3:12
p7:319
p9:303
it seems low
PostPosted: Sun Jan 18, 2009 11:56 am
after some control and brainstorming :
the normal chanel work very good
the tmb with gain att low seting work good too , but when gain is up to 4 or 5 a bad distortion appair with bad harmonics and treble noise
like a clipping distortion
PostPosted: Sat Jan 24, 2009 8:11 pm
ok
i just put a 5751 in v3 and everything is ok
